- HSELUX17
Rear suspension hard
2017 HSE Lux
Ride heights look ok but rear suspension feels very hard and rattles your teeth if you hit a decent bump
Just towed with it for first time and it was really awful to drive , very bumpy and porpoising (best way to describe repeated bouncing)
No warnings on dash
Anyone experienced this or have a solution ?
- Wolfpack
Silly question…Is the air suspension actually working? Normal ride height is default without air….but very harsh and lumpy.
- HSELUX17
Yes suspension works as it should , I just find the rear very hard
- sudds
Anything to do with tyre pressures ? I always put the rear pressures up to 50pis when we have the caravan on the back, tried it once without blowing them up as I was only 1hr from home and found it very floaty on the back end.
Just a thought
- HSELUX17
Did a quick measure from top Of tyre to wheel arch and discovered one corner is 30mm above the other side and rear are different too
Need to get it plugged in and recalibrated I think
