  • Soupy
    2017 Discovery SDV6 HSE Lux Aruba
    Diesel exhaust dosing malfunction
    Anybody had this come up ?
    Original fault was a blocked adblue injector which I removed and cleaned, all good.
    So started the car and the error changed to Diesel exhaust dosing malfunction no restart in 484 miles !
    Any ideas welcome as I need to get rid of this error message before 484 miles.
    The car runs fine with no other engine issues.
    Soupy.
    Zero knowledge of how this system works or the error codes, but if i had just removed and replaced the injector for cleaning, and the fault code changed immediately after refitting it, i'd suspect my intervention had screwed something up? Is it all back together correctly, with no loose connections etc..
    2019 Discovery HSE SDV6
  • Soupy
    Yes all back correctly it’s just 1 power cable and a simple injector which gets blocked by crystallized adblue.
    The car runs fine it’s just the error code.
    The original error code went, see photo.
