  • farley bastos
    Brazil
    Discovery 5 L462 2020 IMC restarting
    Good afternoon, I have a Discovery 5 2020 L462, and there is a defect in the sound that when starting by turning on the engine, the sound restarts after 60 seconds, and the problem repeats itself if I turn it off and on again, I've already changed it the screen, IMC and amplifier, but the problem persists, has anyone ever solved a problem like this? I run the scanner and it always reports a problem with the high speed CAN network! Thank you in advance to anyone who can enlighten me!
    Does it happen every time? On cold start up or after a long journey then stop and restart?
  • farley bastos
    Brazil
    Every time when starting, 60 seconds later it turns off the sound, turns off the screen and turns everything on again…..sometimes while driving it happens too, but rare! I have already tested 5 radios and two screens and the problem always appears, I suspect the BCM, but I did tests and none of the power and network input wires can fall, but I don't have an electrical diagram of all the wires and cables as per their ideal voltage to have With greater certainty, I'm looking to my friends here for an idea of ​​what might be happening! Thanks!
