  • Furnitureman
    3rd Row Seat Belt Clip fix
    As we all know the third row seat belt retaining clips are not fit for purpose so I had a go at sorting them out, they easily pop out of the trim, all you need is a 10mm drill bit or anything of a similar diameter and a hot air gun.
    This is how they supply them 🙄
    Once you remove the clips heat up the area around where they are moulded to the clip as in picture below
    Take care not to melt the plastic, once it feels soft enough push the drill into the opening and hold it flat then apply a little more heat to help the plastic mould to the new shape
    After applying a little more heat remove the drill and whilst holding the end flat against the back push towards the fixed end making sure you hold it until cooled you can speed this up by putting in cold water
    This is how it looks once cold
    And how it looks fitted and works perfectly
    Fantastic mod...I'll get the heatgun out Thumbs Up
