  • Trantorman
    Commercial rear window activation 2019
    hi,
    As per title i am looking to activate the rear windows in a commercial, has anyone on here done it and what is involved, on the D4 is was well understood and easy to do, i would expect the same on the D5 as they get older and pass on to non commercial users.
  • Cordon
    Hello. Did you manage to sort this on your vehicle? I need to do the same.
  • Trantorman
    its work in progress, its very different to doing the D4's, you need to install the rear door modules and the switch packs and them, do a reconfigure of the CCU files, which i will hopefully do in the next week of so.
  • Cordon
    Thank you for the update. Good luck!
  • Trantorman
    Success !
    There's a bit to do to get them working, but its all very doable. you just need to be able to edit the CCF files and remove the rear door cards.
