  • Madrilleno
    2022 Discovery Si6 HSE Santorini Black
    Camera screen frozen
    Just developed a new fault. The camera screen is frozen on an image from about an hour ago. I can get into all the menus, including camera selection on the right hand side. I can select different views, but the image on the left stays resolutely on a picture from an hour ago. Even the view change arrow on the frozen picture moves the RH image as if I’m changing the view, but no change. Tried off-road and towing views and it’s still the same.
    Have you tried rebooting the system? With the ignition on or engine running but vehicle stationary, press and hold the power button for the system for about 20 seconds until it reboots.
    And / or, stop the vehicle, lock it, walk away, have a coffee for at least 15 minutes then see if it works when you restart.
  • Madrilleno
    Seems to have reset itself. It needed longer to shut down fully I assume. I thought ten minutes would have been enough.
