    Seen the Adblue filler,
    Still got me an unused 10l container sitting in the garage,
    Just had no idea of where the range indicator was hiding. Question Question Question Until now. Thumbs Up
    I will check out the range left when I’m next out in the motor.
    Haven’t been putting a lot of miles on the clock of late, so even if I got an amber warning on tomorrow,
    Chances are if I left it, I reckon I’d have close to 12mth before it turned red Rolling with laughter Rolling with laughter Rolling with laughter
    I have an old 1.5L screw top filler bottle from my Volkswagen days, which I cut the bottom off of to use as my filler funnel. Screw it on the filler port, pour in the adblue from the big jug, press down on the filler bottle and let it drain in. Also helps you count roughly how many liters you're putting in.
    If you have the remote app, it tells you the range left in the adblue tank and how many litres it would take to fill it.
    Look under the "status" option.
    Great tip that Phil...hadn't noticed that Thumbs Up
    I can’t find that option on mine but I k ow I’ve got the filler cap under the bonnet passenger side
    If your app is up to date it will ask for a pin number as soon as you click on it.
    If it offers you options before you enter a pin then the app is not up to date.
    Once you update the app, select the "status" option, it calls the adblue "diesel exhaust fluid"
    It should show you the expected range at the current fill level and how many litres to full, if it is not full.
    Good luck,
    Phil
    It’s up to date with a pin but I’ve got no option available
    This is my app.
    I'm guessing there is an option somewhere which needs to be ticked or paid for?
    Maybe have a look under health?
    If I click on status I get this:
    If you click on health, what do you see?
    Looks like you have a different software version.
    I can only suggest you root about in the engine and exhaust sections to see if you can find it.
    If you find it, please let us know where, I'm sure it will help someone.
    If you look in the account section, probably bottom of the page, it may show the software version.
    Mine says 3.0.1
    Is that the same as yours?
    My version is 3.4.1 and the DEF reading is under Health/Exhaust:
