- MAC OSX
Sunroof Drain Pipe.
Please can someone advise me as to where the Left Hand (passenger side) A post sunroof drain pipe exits the vehicle?
D5 HSE Lux 2019
- terryall
Have you tried the cycle brake cable method of poking it down from the top to try and clear any rubbish out?
- B McP
I had a blocked drain pipe on a Disco Tdi 300 and that pipe went down the pillar into the wheel well behind the wheel arch - the pipe had been compressed during build by a piece of sound absorbtion foam.
- ajac
Do D5’s with opening roof suffer the same drain pipe corrosion thet 405’s suffer? My days on the FullFat forum told me it can be a potentially catastrophic leak into the roof void and down posts into ecu’s etc?
Are the pipes easy to access?
