I know it's a small issue, but how do you stop the rear-most seat-belts fouling the load cover when closing it? Am I missing something? Can they be tucked/clipped out of the way somehow?
There's clips for them just inside the rear door, behind the side windows.
The clips aren't very good, they work best (least worst) if you lift the slide the belt buckle up the belt first then let it sit on top of the clip after you've slid the belt in.
Found these on Etsy...a bit more innovative than crisp bag clips. A nice example of an enterprising Disco 5 owner with a 3D printer and a bit of talent using 3DS Max
