    Armrest too low?
    I’ve noticed the drivers side armrest is too low even when fully adjusted to the up position. I compared this to the passenger side and this is exactly the same so I presume it’s a generic problem.
    Is there a method to raise the arm up yet still allow height winder adjustment? Has anyone removed the armrest to cure this problem or maybe yours adjusts fine?
    Mine is currently fully wound to the up position, but comes only just parallel with the top of the centre cubby so practically useless.🙄
    Yeah, if you like your seatback fairly upright, the armrest position is too low at max height. Have the same issue. If you tilt the backrest back, the armrest comes up as well. Can't say I've found an ideal compromise.
    2019 Discovery HSE SDV6
    Re: Armrest too low?
    Mine seems to work fine...could just be where the seat back is...but Mrs Mole's armrest is the same, they're both kinda level with a fair bit of adjustment both up and down.
