- terryall
Success! Of sorts. When I held the “Dead” keyfob against the 3 etched lines on the side of the steering column and pressed the starter it worked. Car started up just fine. But when I take it away from the steering column its does not work. But success of a kind……
- Narpy
Any updates on this Terry?
- terryall
Fob still not working other than pressed against the 3 grooves. Must get something done about it soon in case the other fob packs up.
