- AndrewS
Tailgate open when moving.
FYI the tailgate will open or close if traveling below 4mph. Go over 4mph and it stops moving.
- RDR
Interesting does it just hold its position when over speed? and if so does it hold it well?
Was thinking of using a lighting board hung off the back when I have long loads sticking out the back to ensure I'm legal.
- AndrewS
Yes and Yes it seems to. Not tried it for any length, distance or time. I would imagine there will be a few lights and alarms going off if you continue.
Then there is the issue of ingress of exhaust gasses that won't be very nice.
- Natwest
Wouldn't that be the same set of issues on D3/4 - not a D5 exclusive problem?
Drive along until the beeps and bongs become "white noise"
Could also set the opening position to the desired setting and job done.
Now: 19MY Velar D240 HSE R-Dynamic
On order: 20MY Discovery SD6 HSE w. Dynamic pack
