- squizzel
spotted something while replacing the battery.
- Mole HD
That's a very good spot Squizzel...I'll check that on the Bling Barge for potential issues
Had a look at that part of the rear loom on the Bling Barge this afternoon and there was indeed some signs of chafing. I reinsulated the cable bundle and glued a small section of high density foam padding to the inside of the metal frame where it had been rubbing to prevent any recurrence.
Once again, great spot Squizzel. Thank you
- squizzel
No problem, i would guess that would have been a nightmare short to find, if it had gone through. Glad you have sorted it.
