    Canbus errors?
    Hi All,
    I've been getting a number of canbus errors reported on the code reader.
    The errors return quite quicky after I clear the faults, but I can find no evidence of any physical problems being caused by these errors.
    I wonder if there are any canbus gurus here who could point me in the direction of a resolution?
    Maybe some sort of power reset could help?
    List of errors below:
    BCM (body control module)
    Side marker lamp signal stuck high
    IPMB (Image processing module B)
    Intermittent hs can comm bus, missing message
    Intermittent internal electronic failure
    PAM (parking assist module)
    Canbus not updating
    No subtype information
    Phil
    I suspect they're just background noise DTC's, Phil. I've always got a slew of similar...park assist, heated washers, windscreen demistor, odd camera errors...even though they all work perfectly Neutral
    I've tried chasing the faults, cleaning connectors and checking earths etc, but could find nothing physical either...
    Thanks Mole.
