  • Alwx_Rogan
    D5 LED Instrument Panel Dead?
    Hey Guys, the LED instrument panel in my 2018 Disco 5 started flicking the other day. Generally along with the road surface which I would take as a connection issue somewhere. Then it went black. After a day it came back on randomly while driving. Seems fine for a bit then noticed the very slight flickering on and off. Its gone off again a week later and now appears it may be dead dead.
    I've pulled the instrument panel and done the following:
    Unplugged/plugged in all the connectors
    Checked the fuse. Fuse ok.
    Checked the earth on the drivers side. Tight and clean.
    Wiggled cables. Disconnected and reconnected everything I could reach.
    Reset the vehicle by disconnecting the battery.
    Tried to pull apart the instrument panel until it got to a place where I thought I might end up damaging it if I continued.
    I dont have a scanner tool so havent pulled any codes
    Battery is now on charge as this can be an issue.
    But the flickering with road bumps tells me it probably isnt.
    Any other places/things to check before I repair/replace?
    Cheers,
    Alex
