  • Iansjones
    2021 Discovery Td6 HSE Aruba
    Window regulator
    Hi all,
    I think the front passengers side window regulator has gone.
    Are they the same for pre and post face lift?
    I have seen a lot advertised as up to 2020 and mine is a 2021 face lift.
    Hi Ian.
    All the window regulators I've seen are listed as fitting L462's between 2017 and 2024. So it looks like the same regulators fitted on all models between those years. I've replaced 2 on my 2017 TD6 in the year and a half I've owned it.
    Plenty of good OE quality ones on eBay.
    Just in case you've never replaced one on a D5 before...here's a handy how-to video. Wink
  • Iansjones
    Many thanks for that
    Hoping it is the regulator
    I heard a crunch the other day but all seemed ok
    Then yesterday. Put window down. Put back up. Went half way.
    Then went down on its own.
    Now will not go up more than about an inch. But will go down again
    So guessing something has frayed or snapped
    So will replace with one from the guys in Selby.
    Called a local Indi today £273 non oem.
    Don’t need it that urgently
  • Trantorman
    £55 on amazon, I ordered today, for Monday delivery, I am away Tuesday, Landrover want £270+ vat!
    All the tell tale signs of a rusty regulator cable snapping. The eBay replacements from that place in Selby come with pre-greased cables (and a freebie pair of work gloves) so it's unlikely to happen again. Thumbs Up
  • Iansjones
    Well that fixed it.
    Thanks for the help.
    2021 bronze d300 dynamix (facelift)
    Gone - Defender 110, 2xd4’s, Range Rover sport, disco2,
  • Grunders
    2017 Discovery SDV6 HSE Santorini Black
    Ffs.. just pulled into Portsmouth ferry terminal to go over to Spain… put window down and ping.. dropped to the bottom… good job I’ve arrived early.. had to take the door panel off and cut the remaining rusty cable, managed to wedge the glass underneath.. going to be fun driving round Spain with a stuck window
    Hi Grunders,
    Where in Spain are you headed?
    Phil
    There are quite a few lr parts suppliers around Spain.
    It's a fairly easy roadside fix if you've got some torx drivers?
  • Grunders
    Hi, we’re off to Murcia, fortunately I’ve got tools with me so hoping to get it sorted when we get there
  • Grunders
    Thank you… I’ll check them out when we land
