  • zigg
    Sat Navigation
    cannot get any sound from the sat nav to give instrucstions/directions, pressed the turn on sound feature but nothing happens, has anybody else had the same problem. Thanks
    Is it ONLY the sat nav that has no sound? Is the volume turned down to zero? (Worth asking)
    Have you tried pressing and holding down the power/volume button for 20secs to reboot audio?
  • zigg
    Thanks will try.
  • zigg
    It is only the Sat Nav that has no sound.
    I’m guessing but , if it’s like the parking sensor noise the it’s only adjustable when it’s beeping. So what I’m trying to say is you need to try and predict when the satnav is talking to when you turn the volume up. With the normal volume controls that you would use for the stereo. Gotta be worth a try.
  • zigg
    Thanks will do.
  • zigg
    Still no joy, turned on Sat Nav still no sound, turned the Sat Nav on my phone at the same time, all OK with until I turned on the Bluetooth on the phone to the car and lost sou d on the phone for directions.?
