    2018 Discovery SDV6 HSE Lux Indus Silver
    Finally did my service
    I had got all the stuff to service my car a month or so back. Got to do it yesterday as it hit 5000 from it's last service, which was done by a Land Rover indi.
    It seemed strange to me that the service indicator was saying 2600 miles to next service, but guessed they just hadn't reset the service indicator.
    So while the oil was emptying, which was really black, and quite watery compared to the 5w30 C1 i put back in, i decided to replace the 2 air filters. To my surprise the passenger side had been creased up when whoever fitted it did the job. Leaving a substantial gap which was full of leaves. This filter was a Fram filter, i vacuumed the leaves out and fitted a Bosch filter then went onto the drivers side. This side was fitted properly but still full of leaves, and was a land rover filter. I know it doesn't make a difference, but i would have thought an indi would have fitted the same make both sides. I then fit a new Genuine oil filter, filled it up with oil fitted a pollen filter which the old one looked about 5 years old. Car is now quieter and running smoother. I checked the oil filter for glitter and that was fine, nothing to worry about, reset the service indicator and the oil dilution indicator. Now showing 16000 miles to next service, but it will be done in 5000 miles.
    I've got washable air and pollen filters fitted on the Bling Barge so they never need replacing, just washed out every time I service it.
    The pollen filter is from K&N and the air filter is a Pipercross one from TerraFirma. I've only got a single airbox on my TD6 though.
    For your SDV6 with the twin air boxes I'd suggest... BritPart easy clean performance filter (Pair).
    The K&N cabin pollen filter is a bit on the dear side compared to a chuck away one...but like the washable air filters, especially if you're servicing it every 5k miles, you only pay for them once.
    When you get around to changing the fuel filter, you'll need a set of fuel coupling pliers if you haven't got any. The self sealing couplers on top of the filter are a complete pain to get off without them. Putting them back on is easy enough, just push and click on, no pliers needed.
    Thanks Mole, i haven't got any of those pliers, so i will get some for next service. I still have front and rear diff to do and transfer box, i do have all the oil for those, and i want to clean and paint the fuel tank cradle as it's a little rusty. I have already replaced rear brake pads, and have the fronts still to do, but they still have a bit of meat left on them. Got to do front brakes and new steering knuckles on my sons 1995 jeep YJ first.
