  • Snapper1
    Spare wheel fitted
    So 3 weeks into ownership and i have fitted a spare wheel, seemed quite easy although i thought i had the wrong heat shields, offering them up and i thought way to big will never get them in, tried always around and then 1 just fell in the second was a doddle from there, it is worth getting the 4 nuts that hold the heat shield to the body as they seem to be a strange thread, all the others are standard 6mm, i used 4 bolts on the heat shields and 4 nuts and 2 bolts on the winch, i also used 2 x 8mm nuts and bolts on the guide by the rear wheels.
    Big thanks to Will at Duckworth Parts for helping me out and getting the bits sent over exceptionally quickly. Thumbs Up
    Just need to tell the Disco now so the TPMS can work.
    The D5 doesn't show the spare tyre pressure on the centre dash TPMS display, at least not on my ancient Bling Barge... it only shows the 4 tyres fitted on the road wheels unlike the D4 which showed all 5 tyres...
    I think it'll warn you if the spare tyre pressure is low...but no idea why it doesn't show up on the centre dash along with the other 4. Might be different on a D350, but the full size spare wheel was a standard fitting on the early D5 models and not an optional extra as far as I know.
    I think there was an option on the facelift models for either a full size matching wheel or a space saver on new cars...before Land Rover decided to offer a spare wheel of any sort as an optional extra rather than being a standard fitting.
    Took me years to get used to not having one stuck on the back door...I missed it so much, I fitted a rear swivel mount on the D4. Laughing
    On my factory fit spare tyre on. My former D5, I can’t remember if the spare tyre came up on my display normally, but it certainly popped up if the pressure was low.
    TBH a full sized spare it an absolute tw*t to fit at the roadside. I simply wouldn’t try it, especially in the dark and particularly with the crappy jack and wrench they supply.
    I’d either call out LR assist to change the tyre or I am favouring the repair kit tbh.
    Aye, I keep an old self inflating camping mat in the boot just in case I have to crawl around in the muck at the side of the road getting the spare off the D5.
    One of these wheel stud extenders certainly helps when sticking the wheel on the car though...
    I had a 4' hi-lift jack attached to the side of the roof rack on the D4...but not having a rack on the D5, it's now hung on the wall in the garage. Neutral
  • Snapper1
    You can get the spare wheel as a full size option on the D350 but most don't have it, and trying to find one with the other options i wanted was not easy so decided to widen the search and fit my own, the manual says it only warns if it is low pressure and doesn't come up otherwise. once i get it paired to the Disco i will let you know, and yes it will be awkward to fit but i would rather have it than not, i have never used a repair kit but don't fancy fiddling around with that and then continuing my journey with a caravan on the back. isn't the tyre ruined after you use the repair kit? the Stud extender seams a good idea, will have to get me one of those.
    There is a lot of urban myths about liquid repaired tyres. Having used it when snowing hard at night, it was quick, simple and effective. There are renowned organisations online that give you the low down on its use.
    Some garages used to be awkward repairing tyres with the liquid applied, but now a days most will, probably because the majority of vehicles seem to use them. I’ve seen the garage clean the inside of the tyre of the liquid, it takes a couple of minuets tops.
    Of course a repaired tyre is only a temporary measure, but it’s perfectly safe to drive on towing or not towing.
    Each to their own.
