  • Pusser
    MHEV Batteries
    Just got a new 26 Metropolitan D350 MHEV Very Happy
    Does anyone know where the 12v and 48v batteries are? Noticed the boot doesn’t seem to have the removable panel where my previous MY18 12v battery was.
  • BAZ8046
    2022 Discovery Td6 S Carpathian Grey
    Congratulations on the new car.
    As far as I know the 12v battery is still behind the drivers side panel in the boot.
    It definitely is on my 2021 D300 unless it has been moved on the later cars.
    If you remove the small panel where the jack is you have to get your hand in and move a slide back at the top of the adjacent panel.
    This is not a great design and is awkward to get to but once you know how it works it's ok.
    I believe the 48v battery is under the car but will have a look next time I've got the car on the ramps.
    I've not been able to find a workshop manual for the facelift cars but I'm still looking.
    Hope this helps.
    The 12V battery is where it has always been on the RHS of the boot.
    The MHEV battery (48V i think) is underneath the car.
  • DG
    48v is under the motor as said - appears midway if you look at this vid of a removal \ replacement
    https://www.instagram.com/reels/DPB4mo6EtSN/
    23 year LR veteran > D2 GS 2003 > D3 S 2006 > D3 HSE 2009 > D4 HSE 2013 > D4 HSE 2015 > D5 HSE 2018 > DS HSE R-Dynamic P300e 2021 > D5 HSE Dynamic D350 2025
  • BAZ8046
    I was under the car at the weekend so had a quick look at the battery location.
    As already mentioned it is under the drivers side around half way down.
    From the wiring it looks like the DC-DC converter is under the cover on the passenger side but I didn't remove the cover to check.
