- cropps
P2455-22 DPF Filter differential pressure sensor - circuit h
Good afternoon all
New to the group and had a look around to try and find a related issue but failed.
From what I can see on the internet it looks like I need to new pressure sensor.
Trying to find one is proofing difficult, I have a 2017 SE 3l diesel.
I have added a photo of what I believe is the part I need.
Any help would be appreciated.
- Mole HD
Think this is the part you need...though I can't see your picture to verify. I found a couple online from various outlets...there are more if you search around since DPF pressure sensors are a fairly common part.
Scuderia Land Rover
Famous Four LR Parts
Maltings 4x4 (out of stock but can be ordered)
Autodoc Various brands and cheapest by far. Don't worry about the Ford OEM numbers...the Discovery 5 3.0L TD6 and SDV6 are Ford Lion engines. I checked the part numbers on Autodoc out for my reg number and VIN... which is a 2017 3.0L TD6, same as yours.
Hope this helps.
- cropps
Afternoon and thank you for your assistance, mush appreciated.
- Mole HD
You didn't mention what the issue was that needs the DPF sensor replacing. I'd be interested to know.
