  • ChaddersP
    2019 Discovery SDV6 HSE Yulong White
    Restricted performance warning 🤬
    I’ve had the restricted performance warning message come on with the red exclamation mark in the red triangle! Then can’t go above 50mph. It goes off and resets when you turn the engine off and resumes normal performance. It will come back on around 3500/4000 rpm under acceleration.
    In short chat GPT points to turbo issues which makes sense when accelerating. I’ve booked it in for diagnostics. However what’s your experience and best guess?
    Hopefully it’s not typical poor landrover reliability 😤thanks
  • BAZ8046
    2022 Discovery Td6 S Carpathian Grey
    Hi, on the SDV6 it is normally either an air leak or a sticking actuator on the secondary turbo or cross over valve.
    A read of the codes should point you in the right direction.
    Here is a screen shot of the codes from my old car last week which has the same symptoms and does have a sticking actuator.
    Hope this helps.
  • ChaddersP
    Thumbs Up would anything relevant have been disturbed when the belts were done? Only happened since then
    Unfortunately can’t see the image even when zooming in
    It’s a knocking bet there’s a pipe off or not properly refitted after the belts were done.
    Ask me how I know. Embarassed
  • ChaddersP
    How do you know? 😊
