After owning my disco 5 since January (preowned 2018 reg, 2019 model) the weathers finally turned for winter and I've found it has a leak.
After initial inspection I am pretty sure it's coming from the back left somewhere. It's almost certainly not the windshied as that was previsouly replaced and I've tested for air leaks, dash area is dry inc the air intake filter and surrounding area.
I've attached a picture of where it's the most wet, essentially the water seems to be running along the rails of the left rear passenger seat rails. I havent traced it any further from there yet as everything feels dry past that.
I managed to wet vac quarter of a bucket of water out just after the last 48 hours of rain.
Anyone with experience know what to do / check next?
TL;DR
Turned out to be that the near side rear sunroof drain tube had come apart on mine.
I managed to catch it early after a so called repair & the first sign of water inside again was under the n/s middle row seat.
Essentially slide the middle row seats forward my carpet was as wet as hell.
My current suspicion is the sunroof drains like you say. Its definitley rainwater and not screenwash or anything else and the door seals look ok.
Ive put some electrical tape over the sunroof gaps in an attempt to limit the water getting in as its non stop raining at the moment and hopefully if less water is poolung up that at least points in the right direction.
Im going to maybe try and have a look at the nearside exit point for the drains to see if they have popped out. Problem is it seems to be behind a ventilation unit at the side of the boot from what ive read so will have to figure out how to get that out first.
