  • Trantorman
    Alarm Motion Sensors, permanently disabling them
    I have a 2019 Commercial and every time I leave the dog in it, its sets the alarm off unless you go through the Menu option to Disable the interior sensors, which works but is a total pain to do every time.
    I will contact GAP for the way to disable them permanently with the ID tool, but before I do that is there something I am missing.
    On the D4 you just used to double Plip the remote locking, but that does not work on the D5.
    what do you do if your leaving the dog in the car?
    If I don't want the motion sensors on...like for when I'm I'm on the ferry... I just single lock it instead of double locking. No idea how to turn the volumetric sensors off though...
  • Trantorman
    single locking works for the vehicle sensors, but not for the motion sensors inside. sadly
    Single locking has been the way I've left my dog in all 3 of thee D5s I've had. It turns activates the alarm for door opening but disables the interior motion sensors.
  • Trantorman
    thanks, i will try it again, seems strange that there is the option via the menu, to turn them off, if you dont need to too!
    Thanks for posting that info.
    The menu option lets you have all the other features of double locking (e.g. not being able to unlock the doors from the inside if someone breaks a window) but still disabled the movement sensors.
    Should that additionally read “without the key fob use”.?
    I can open my boot with the remote while the rest of the car remains locked.
    I know this because I have a habit of opening the boot remotely from within the house, then discovering what I want is IN the car, not the boot, and having to come back in the house to unlock the car. Rolling Eyes
    However, I’ve never checked if the double lock comes off temporarily defaulting to single lock, and then resets on closing the boot.
    I think it does...I do the same if we've unloaded bags of shopping, double locked the car then going back half an hour later after we've put the shopping away and popped the boot open with the fob to put the empty shopping bags back in the boot storage. When I close the boot lid again, the indicators flash and I get a single beep as it closes to signal that the alarm has been reset. Saves having to unlock the entire car just to open the boot I suppose.
    The alarm only activates if the car doesn't sense a key fob within 3 meters or the boot isn't opened with a remote button press from the fob once the alarm has been set.
