  • No Worries 4X4
    2020 Discovery SDV6 HSE Corris Grey
    D5 Heater Controls
    Hi there, can anyone tell me where the internal cabin temperature sensor is located, i need to see if mine is blocked or broken as my heating either burns my face off or freezes me to death.
    Can be going along quite happily for 2 hrs on 20deg and the all of a sudden its blowing cold turn it up to 22 and it cooks you.
    I am suspecting it may be in the rear some where and as I have a Commercial this may be being blocked, my D4 commercial had simalar issues.
  • tomekw
    Poland
    2017 Discovery Si6 HSE Lux Aintree Green
    piece of trim where. engine start button is
  • No Worries 4X4
    Maybe on the D4 there is a grill under the start button but not on the D5, no little grills on the facia
    From what I dug up online...
    Quote:
    The Land Rover Discovery 5 (L462) cabin temperature sensor is located behind a small grille on the right-hand end of the dashboard, accessible by dropping the panel below the steering wheel.
    Tomekw is correct...but his is a left hand drive model. Unfortunately, the D5 workshop manual I have only shows the sensor location for the LHD model too, as in the illustration below...there's no illustration or description of where it is on RHD models. I'd assume it's in the same place behind that piece of trim under the start button...but I couldn't find a definitive answer anywhere online. Neutral
  • nebc100
    I will confirm… on a LHD car it is there. I had to replace mine!!
    Really easy repair unlike on my wife’s epace.
  • No Worries 4X4
    I have found it, it is hidden under the crank in the indicator stalk next to the starter button but hidden arround the corner. The D4 its under the starter button.
    Ill get the cover off at the weekend and see how much crud thw fan has pulled into it.
