- ChaddersP
There’s a rat under the bonnet what am a gonna do?
As the subject title suggests 🐀 poo has appeared under the bonnet. I understand ultra sonic repellents can work? There’s one that can connect to the 12v supply. However where would I connect under the bonnet because the battery is in the rear? Thanks
Anything will be cheaper than a chewed wiring loom
- Wolfpack
I got 2 of the ultrasonic thingies that supposedly deterred squirrels.
I sent them back for a refund along with photos of two squirrels sat 3-4” away from the devices, happily eating the bird food.
Rats are a nightmare. A close friend had them nesting in his loft having climbed up the cavity wall. Spent thousands with Rentokil but the only thing that finally worked was discovering where they were coming from (in his case up the sewer) and blocking that route.
- ChaddersP
They are a nightmare I’ve had them in a house I previously lived in in the wall cavity coming out at night in the kitchen under the kick boards caught about 4 the rest were poisoned then they stank for about a month.
The ultra sonic thing is only £16 on Amazon so worth a punt
- harrythespider
Try BITREX, usually a powder , mix it with water and spray where you think the rats may chew. It really is foul stuff if you get the smallest ammount anywhere near your mouth!!!
