- PRH
Is it the earth stud
Long story short - ish.
2018 2ltr HSE Lux. Battery went totally flat in April 23. AA fitted new battery, it went dead within 24hrs. Recharged and took car to Indi, they reported no adverse drain on the battery. Been OK since with the standard ‘low battery’ warning on occasion which went away for a while after a good charge.
Eventually message started to get more regular so as battery had five year warranty just got the AA to replace it two weeks ago, he said he reset the BMS. Been OK since with stop start eventually working but as soon as the engine stopped it restarted without drawing breath!
Went out today and forgot to turn the stop start off on one leg of the journey, car stopped at a junction, went dead, then dashboard lit up with all sorts of warnings. Car still in Drive but no running engine. Went back to Park then Drive, engine started, we continued our journey with warnings suppressed.
Got to the pub, parked, came out, car started no problem.
Got home, pulled into drive, stopped the engine, car went dead. Nothing, can’t lock or anything. Can’t open the boot to get to the battery. Opened bonnet, voltage on the jump start studs about 3v. Connected charger, digital screen flickering from 5 to 6 volts (approx).
Connected wife’s car with jump leads, lots of sparks but car comes back to life as if nothing had happened! 🤬
Edit - forgot to add, I have a Bluetooth battery monitor fitted on the battery, it could not connect when the car was dead, the monitor is connected to the positive terminal and the lower battery clamp so does not bypasses the earth stud.
Two positives - we had made it home and JLR phoned to ask if the car is OK.
Question(s): is this the dreaded earth stud problem or, what else should I check?
- Mole HD
It certainly has all the hallmarks of being the earth stud as the culprit, move the earth strap onto one of the alternatives in the meantime and it should sort those issues out.
- PRH
Brill, thank you. Guess what I am doing tomorrow ……
- Narpy
On the D3 and D4 your symptoms we’re synonymous with a failed/failing alternator but I’m unsure if this applies to the D5.
A failing alternator has all the hallmarks of a tired battery, so you obviously replace it and normal service returns until the following day when your new battery is also paggered. If you get her running again, check the alternator output across the battery with a multimeter. A good reading is well over 12v, preferably over 13v and nearer 14+v at initial start up.
- PRH
Thanks Narpy.
The AA man did do a check and said the alternator was charging fine, the old battery was not taking the charge.
I will move the negative lead and do those checks. I am also going to check the voltage across the battery and the other end of the negative lead before I do any work to see if there are any tell tale signs. I also hope that visual inspection of the connection will tell me something. I fear that not identifying any issues will leave a distrust in the car which will be hard/long to overcome and I am due to travel down to Tavistock next week, a 3 ½ hour journey…… 🤞
