  • BAZ8046
    2022 Discovery Td6 S Carpathian Grey
    D300 auxiliary belt, tensioner and idler.
    I'd had a squeak on my auxiliary belt for a little while and decided I'd better get it sorted before it got any worse.
    I ordered a new belt, tensioner and idler which were all OEM.
    The total cost was £257 so not too bad for a LR repair.
    Mine had the above items replaced under warranty at 50k and has now done over 120k so it's not a surprise that they need changing again.
    This seems to be one of the few weak points on the D300 engine so can't complain too much.
    The first thing of note is that the idler has been updated and is now a completely different design.
    There is a recall out for this on newer cars but not for mine which is 2021.
    The new design has two location tabs whereas the old one only had one.
    From the recall notes I'm guessing the single tab could break off and the idler allowed to rotate which would then hit the oil pressure sensor.
    These are the old and new side by side:
    This job is straight forward however the limited access does present some challenges.
    The idler can be removed from the top but the access to get your hand in is tight.
    You can remove the coolant pipe across the front to gain better access but I just used some cable ties to move it out of the way.
    For the tensioner I couldn't find a way to get this out of the top.
    The easiest way I found was to remove the nearside air box and bring it out through the side.
    To do this there is a small coolant line clipped to the back of the fan shroud that needs moving out of the way.
    All the bolts are accessible and the torque setting is 25Nm for all bolts.
    On mine the two small pulleys on the tensioner were worn as well as the belt.
    I'm fairly sure it was the pulleys on the tensioner that were causing my issues.
    They are both a small diameter so have to work hard.
    My idler was ok but I'm happy I changed it out for the new design to prevent any future issues.
    Hope this may help someone in the future but any questions please just ask.
  • harrythespider
    Good description and photos, Looks like its a fairly easy job.
