- S2bear
Curry Hook Fix... kind of...
For those of you who's 'curry hook' stays depressed / stuck in, like mine does. If it bothers you, just tap the panel firmly below the hook, hopefully it should spring back flush. Can't believe I'm posting this for a motor that costs this much but there you go.
- Russell
Take it back to dealers and get them to FIX it
- S2bear
I hear you. I've been to the dealers and after two days in the shop they forgot the curry hook off their list of faults, said there was no software update for the tailgate and the technician couldn't find the squeaking in the dashboard, (despite a video showing exactly where it was, and the receptionist being able to find it without any problems). They fixed the most annoying fault (Loose connection for a/c controls) and offered to work on it for longer but the thought of the dashboard being taken out and reassembled just seemed like opening a can of worms to me. So, I found the offending movement in the dash (by the upper glovebox) and inserted a 2mm rubber washer into the gap (can't be seen as is under the glovebox door) and it seems to have fixed the problem 95% for the moment. It's not right to spend this amount of cash and have to remedy faults DIY fashion but it took 1 minute, was a simple means to a hopeful end and LR aren't the only Marque with creaky dashboards. I'm trying to move on to a happy place and not think about the niggles.
- Road Runner 2017
Well at least its better than a dodgy engine mate - swap you a dodgy curry hook any day
- J77
My car doesn't come with one
