  • S2bear
    Anyone else's roof lining falling down?
    Mine's gradually collapsing 😔
    Sorry. Should've put this under Faults
  • J77
    Not that I've noticed.
  • Teemo
    I can't work out what you've taken a picture of...
    Where is the lining collapsing?
  • S2bear
    See the white line below the rubber seal?
    That's the inside / raw edge of the roof liner panel which is dropping lower. Normally that would be hidden by the rubber seal above it.
  • Teemo
    When I originally looked on my phone, I couldn't tell where the picture was actually taken. Looking on my PC, I can see the rear seats so presume the problem is along the top of the tailgate.
    O/T I see you have the same car seat us us. Have you got a seat cover? Doesn't look like it. We've got one of these and it kept our D4 seats pristine.
    https://www.amazon.co.uk/Britax-2000009538...B00COFVCYW
  • S2bear
    Hi, yes I have a seat cover but the one you sent a link to looks much better, think I'll get one of those, thanks for sharing!
  • J77
    Checked mine today, alls good. My one must have went through quality control.
  • Khauff
    J77 Rolling with laughter
  • J77
    Here's proof, found it in the boot
    Keep up the good work Martin, you're an asset to JLR, a true ambassador for Land Rover. How about passing some of your Knowledge onto your colleagues?
    Should get a mention as employee of the the month me thinks. Thumbs Up
  • DiscoStu
    Probably a supplier QC check, not a LR one. Sorry chaps.
    MY19 Silver HSE Lux SDV6
    Irrespective, it's still been checked Laughing
  • Platypus47
    Re: Anyone else's roof lining falling down?
    Mine looked like that in the D4 after I'd put rear view dash cam in. Just needs to be pushed back up under the rubber seal.
  • S2bear
    I've pushed this back up above the rubber seal lots of times but it won't stay up unfortunately.
  • Platypus47
    Are the plastic 'plugs' that hold the head lining in place properly pushed in? Give the headlining a thump with the heel of your wrist a few inches forwards of the trailing edge and see if that raises the lining more permanently. You can see where these 'plugs' are if you pull the headlining down a bit.
