  • J77
    Exterior A-Post
    Checked topix today and it appears I have an outstanding campaign
    N042 - Exterior A-post trim adrift
    Can't say I've noticed anything.
  • GNWallace
    Mine seem loose to the touch - flimsy if I'm honest!
    How can I check Topix?
  • J77
    Register here, though you need a paid subscription to view full details
    https://topix.landrover.jlrext.com/topix/vehicle/lookupForm
  • GNWallace
    Thanks, just wanted to browse.
  • Seaby
    mine came lose at motorway speed and caused a massive amount of noise as it vibrated against the A pillar trim. Stuffed it back in with a credit card but would come out when wipers were on as that disrupted the airflow around the windscreen /. A pillar.
    Sorted by dealer along with new black gloss trim on the A pillar as this had been damaged by the trim.
  • J77
    I'll have a play around tomorrow.
    One thing I have noticed is on the drivers side the small black plastic trim between the passenger door and 3rd row window seems to be coming loose.
  • winger
    There's a SSM for that one....
    SSM73324
  • J77
    I'll add that to the dealers to do list.
  • rd450
    How do you get access to topix?
  • J77
    Register using the link further up then you have the option to buy a subscription, usually when you click on a bulletin it gives you the option.
  • J77
    Checked my A-pillar trim, seems rock solid.
  • Scrumps
    It's not the trim, it's the rubber seal between the A-post trim and the screen.
    It breaks loose from the trim and flaps across the screen, very distracting and makes a horrible noise.
    Just had our off-side done under warranty but had to wait for a "modified part".
    Just checking if it has to go back to have the other one done under N042.
    Scrumps
  • J77
    Ahh ok
    Nothing seems loose, no rubber flapping around but I will have another look now I know what it is. No harm I suppose in getting the dealer to look at it while it's in getting the little bit of trim stuck back on.
  • Landieman
    Anyone got any pictures or the topix note they can share? Mine feels 'loose'(ish) to touch if I push the top?
    That is the issue, I had mine fixed a couple of weeks after delivery and obviously it turned out to be a common fault.
    Once fixed it is rock solid.
