      - Tedworth
      HUD Brightness - Seems to be stuck!Morning
 Does anyone else have any issues trying to dim the brightness of the HUD? Mine seems to be fixed on a very bright setting which is OK during the daylight hours but a bit dazzling at night.
 Any tips most welcome, please.
 Otherwise I'll leave it until an AdBlue top up is required.
      - Dave97v5
      I have had problems with mine on several occasions and usually when I have a car full of people
First thing to do is check the settings and make sure it is set to AUTO as it will stay bright if not.
It should auto dim into night mode but it needs to be quite dark before it works.
Worth a try before complaining to dealer.
      - Tedworth
      Thanks Dave
 The adjustment on it seems minimal but I can just about see the brightness changing. I'll give your auto setting suggestion a try.
 Otherwise, the car is excellent!
      - PeterW
      I haven’t found an auto setting for the HUD ?
 I adjusted mine in the pitch black, lowered brightness till the glare and the outlinebox thingy just disappeared.
 Seems ok in all conditions now.
 Peter
 HSE 3.0 V6 Diesel Corris Grey
      - Jacko
