Has anyone had centre entertainment screen haze over with purple or green tinges? Had it happen about 3 x times over the last 5 months, once the vehicle is restarted again, the screens go back to normal again.
2018 HSE LUX, Built December 2017.
I've not seen this on a D5 screen, however it looks very much similar to when you get a faulty connection to a display or monitor. As the connection handles Red, Green and Blue signals (i.e. RGB), then a dodgy connection on one will cause this sort of look. Sounds like it happens when the display is warm, so that would also confirm this might be the cause.
Had it many a time with displays and monitors and it can be caused by a faulty cable, or a dodgy connection. Most definitely a workshop job I feel.
I’ve seen this 3 times in the past 3,5 months on a MY18 HSE
After restarting it is back to normal - going more or less in parallel to the radio and/or navigation just stopping to work
You cannot create new threads in this forum You cannot reply to threads in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
