  • GP1200
    Centre Entertainment Screen Hazing Over
    Has anyone had centre entertainment screen haze over with purple or green tinges? Had it happen about 3 x times over the last 5 months, once the vehicle is restarted again, the screens go back to normal again.
    2018 HSE LUX, Built December 2017.
    Thanks Jack
  • rogersmj
    I've not seen this on a D5 screen, however it looks very much similar to when you get a faulty connection to a display or monitor. As the connection handles Red, Green and Blue signals (i.e. RGB), then a dodgy connection on one will cause this sort of look. Sounds like it happens when the display is warm, so that would also confirm this might be the cause.
    Had it many a time with displays and monitors and it can be caused by a faulty cable, or a dodgy connection. Most definitely a workshop job I feel.
    MY18 Corris Grey HSE Lux TDV6
  • GP1200
    Hi Roger,
    It happens when it’s cold, normally when it’s been left overnight in the garage.
    I don’t think it’s done it yet when vehicle has been hot.
    At least it’s not a common fault ( have put it on 3 x D5 sites so far and no one else has the same problem yet...)
    It’s not really a Land Rover unless it has some annoying electronic gremlin to remind you.........
    The other good thing is I have another 4 1/2 years of warranty “ to let it develop “
  • Jjyoungjsy
    Jersey
    I’ve seen exactly that too. But only once in six months!
    Santorini Black HSE Lux Si6 with Black Pack, HUD, TV, Park Assist & 22"
    Yes its just the CRT warming up. I understand they found some old stock and fitted to some vehicles that they shipped overseas Rolling with laughter
  • Johnson
    Belgium
    I’ve seen this 3 times in the past 3,5 months on a MY18 HSE
    After restarting it is back to normal - going more or less in parallel to the radio and/or navigation just stopping to work Sad
