  • LPan
    Help with Live and Pro services pls
    I picked up my MY17 TD6 yesterday and need some help with the live services please.
    On a RRS I had a few years ago it would pick up safety cmeras and alert you if you were approaching as well as traffic updates. I was told by the dealer that the only way to get this nowadays is through a SIM card service. Is that right? But as I drove home from the dealer it was picking up a few cameras on the M1 so I'm a little confused.
    Can someone clear it up for me please?
    The ones it was picking up were probably fixed ones on a satnav map?
    The camera database is built into the sat nav.
    You should have the remainder of the 3 years of services. To get the live traffic you will need a SIM card or connect your phone as a hotspot.
    Create an account here: https://incontrol.landrover.com/jlr-portal-owner-web/login
    There is a help button to a PDF file.
    and here: https://www.landrover.here.com/#home/0
    The second one will also give you access to map updates.
    Hopefully the previous owner or dealer has "released" the VIN?
  • LPan
    Thank you. I've just ordered a SIM card and set up those accounts. I believe once SIM is in the car I sign in and its good to go?
    Should be!!
    There is a new map version today, so if you have a 32GB stick then you can pass the time downloading that! Whistle
  • LPan
    How do you do that please and how do you know a new map is available? If I have a SIM card in the car then will it not automatically download when a new map is available?
    You will get a message on the car screen telling you about the update.
    20+GB is too much to send via a SIM, you will find the map download on the HERE site I posted above
    Also do a search on map update, I posted instructions sometime befog.
  • LPan
    Ah Ok, makes sense. Thanks once again. I've just gone back in to the HERE site and logged in and it hasn't saved my car when i entered the VIN number. it seems I need to log in via the car when I get the SIM for it to connect the account?
  • Tempted
    When you set up your InControl account, it'll ask if you want to be notified of map updates. You would then download the map on a computer, out it onto a USB stick and install in the vehicle.
    Downloading map updates via your data sim would soon blitz your allowance.
  • LPan
    So got ther SIM card and all seems well. Also managed to connect to the house WIFI whilst car is sitting on the drive. I have set up for traffic updates on the satnav and for rerouting. I know these eat some data but I assume only when it needs to be searching for traffic updates whilst routing me using the SatNav. That correct?
    Also, whilst connected to WIFI I went online to the HERE site and it had all cars listed for the latest maps apart from the Disco5! I hope I did it right.
    I use a Three SIm which is 12GB for a year, live traffic is updating all the time but uses very little .
    At the end of the year I always have data left.
    You are probably going to the wrong place for updates, there is no choice of car!
    There is a post I made with a step by step guide, but simply go to https://www.landrover.here.com/#home/0
    Login and map updates are in the top right corner.
