- frwamati
Wires from engine compartment into passenger area
Is there a spot where i could "somehow easily" feed a few 1,0 mm2 wires from the engine area into the passenger compartement?
I need to add 2 siren speakers and grille lamps that will be controller via the master controller that sits inside the passenger compartement.
thanks
