- duc1098
Air compressor problem?
Hi.
Just got my first D5, 2019 HSE Luxury. I have noticed that the air comressor runs very often, and for several minutes every time. Is this normal? I didn't hear the comprssor in my previous D4's at all, so i'm wondering if something is wrong?
Jan G
- Russell
Where can you hear it as it is in a different location to D4
- duc1098
I can hear it when driving, sounds like it's placed somewhere near the rear axle.
- DieselRanger
There was a TSB issued to replace the valves on the air springs - check to make sure yours was completed. I don't have the TSB number but if someone has a TOPIX account it should be easy enough to look up. I believe the valves could fail, which could cause the compressor to run excessively.
Replacement at my dealer took about 2 hours.
