- Keith
Easy Entry & Exit
Hello
As the title suggests, do all models have the easy entry and exit (seats move) ?? I have the R Dynamic SC, can’t seem to find the settings so may not be fitted / enabled.
Keith
- Equilibrium
I think its a case of turning the steering wheel adjustment switch, it also functions as on/off for the wheel/seat movement.
- Keith
Equilibrium
Good suggestion. Mine is set to manual, I’ll give it a try.
Keith
- teaman
Also check the “Convenience” settings menu on the steering wheel. If you have air suspension you can configure it to automatically lower to access height (when opening the door / turning off the engine)
