  • Keith
    2021 Discovery Td6 SE Santorini Black
    Easy Entry & Exit
    Hello
    As the title suggests, do all models have the easy entry and exit (seats move) ?? I have the R Dynamic SC, can’t seem to find the settings so may not be fitted / enabled.
    Keith
  • Equilibrium
    2019 Discovery SDV6 HSE Lux Carpathian Grey
    I think its a case of turning the steering wheel adjustment switch, it also functions as on/off for the wheel/seat movement.
    Drives: 2020 MY20 HSE Luxury SDV6 in Eiger Grey/Glacier
    Departed: 2019 MY20 HSE Luxury SDV6 in Carpathian Grey/Glacier, 440i, 320d, Toyotas, Mondeo, Citroen BX amongst others
  • Keith
    Equilibrium
    Good suggestion. Mine is set to manual, I’ll give it a try.
    Keith
  • teaman
    Also check the “Convenience” settings menu on the steering wheel. If you have air suspension you can configure it to automatically lower to access height (when opening the door / turning off the engine)
