  • Lamm75
    Rear air suspension valve
    Hi guys, im new to this forum.
    Im trying to learn the Disco 5 air suspension plumbing.
    Im hoping someone can explain the plumbing for the air suspension rear valve block in partucular
    The yellow/orange 'RR' is rear right i assume?,
    Green is 'RL' - rear left i assume?,
    Is white 'P' pressure? Is this the delivery line to the front valve? Or feed from compressor ?
    Is black 'RES' is this to the air tank? Or feed from the air tank?
    Also the larger 8mm hose... what does this hose do? Is it a dump hose?
