- Mole HD
An update on checking all 4 window regulators. Found on one of the rear doors that the window outer seal was folded over and creased, possibly allowing water to get into the door...we get far higher than average UK rainfall up here so it needed addressing.
Took a while to straighten the seal out so it wasn't going to fold over again but on close inspection, the window regulator cable didn't look too bad apart from some surface rust...cleaned it up and sprayed all the cables in all the doors with some water repellent grease...sorted
