- Johnson
Multiple errors (post full flat battery)
While my Disco 5 (3.0 Diesel MY18) is still at the garage, quick check if the below sounds familiar to anyone:
I had to start the car with a booster as the battery was totally flat (no unlock with fob)
after couple of 100m driving had following errors:
Gearbox fault / HDC not available / Stability control not available /
"D" blinking and no possibility to move gears selecter knob.
Could these be the result of the full flat battery? or is there more behind these group of errors
Any thoughts appreciated
K
