- rene4jazz
DIY Control Arm Replacement - Stuck on Height Adjustment
Hello, I've spent hours searching for the standard height specifications, measured from the hub center to the flange or fender, but couldn't find them. Can anyone provide the correct numbers and clarify which reference point (flange or fender) is accurate?
I've only found the procedure for calibration using diagnostic equipment and a special measurement tool. However, since I'm replacing control arms, I need to set the nuts at normal height first. Without this information, I'm stuck and can't move forward with my DIY project.
Thanks in advance for your help!
