- Beno2
Rear wash
Can someone just confirm what there rear wash is like in terms of water spray. When I push the button I hear the water above my head in the roof lining then it comes out the rear just running down the glass with no no spray pattern?
- Mole HD
Mine is pretty good, plenty of pressure and a good spray pattern. Sounds like yours has an airlock or blocked nozzle.
- Darras
I’ve also heard the washer water above my head since the car was new. The spray pattern is non existent. I never looked into it further tbh.
- Duckers
I had a similar problem, pump working but water running out of the tailgate near the camera, the supply pipe had split. All replaced under warranty and fine now.
Regards
