- leeroy
B105A-13
Had a heating issue recently while driving back from france. PLugged the scanner in to find this new code "B105A-13" 1.Passenger Compartment Temperature Sensor Fan - Open Circuit
Looks like the sensor is on the side of the steering wheel and you have to remove the trim (with the start/stop) button on it to get to it..
the error says the fan has broken but i think the fan is part of the senor..
Anyone else had this problem? or has anyone else taken that panel off before?
- leeroy
any help in terms of trim removal most welcome as the trim panel is now stuck half off but I cant get it back in to positions ;-(
luckily the start/stop button still works so I can drive it
