- D5spain
E-Diff
Hello, greetings from Spain. I bought my 2019 D5 with 138,000 km. In less than a year, at 146,000 km, piston number 6 was damaged. The engine was recently completely rebuilt and currently has 150,000 km. A noise has started coming from the rear. I thought it was coming from the differential, but when I put it on a lift and the rear wheels were resting with little traction, the noise is coming from the wheel area when I start the engine. It's a metallic clacking sound, and it doesn't sound like a CV joint. It only happens at low speeds, regardless of the steering angle. Even with 100% engine load, the rear axle vibrates.
