    New Map available
    My current map version is 08.030.0067.0153
    There is a version available now 08.030.0070.0153
    I am downloading it at the moment, had no trouble with the car recently but that could all be about to change! Rolling with laughter Rolling with laughter
    https://landrovershop.here.com/web/WFS/HA-...roductList
    The manual looks good as well!! Whistle Whistle Big Cry
    https://landrovershop.here.com/static/WFS/...manual.pdf
    Well that went very well, Download was 22GB and put the USB in the car and all done in less than 30 minutes.
    No idea what has changed though!! Thumbs Up
  • Teemo
    I just get 'general error' when I click on either of your links.....
    OK,
    Go to the Route Planner Homepage and login.
    Click on Maps and Services.
    You should then get a list of Connected Services for your vehicle
    Click on Get latest version of Europe and Russia and
    then you should have a page inviting you to download a copy for your VIN.
    I think my link maybe for my VIN only?? Thumbs Up
  • Teemo
    Very Happy
    Worked a treat - I had the same original map as you.
  • Teemo
    New map is 17GB so you'll need a 32GB USB or larger.
    If you have Windows 10, it won't format the drive as FAT32 which the Landrover updater requires (it will only do exFAT and NTFS, neither of which work).
    I used this program to format the stick correctly:
    http://www.verbatim.com/index/search.php?words=fat32+tool
    Odd about the formatting, I have Windows 10 and formatted OK.
    That's computers for you. Rolling with laughter Rolling with laughter
  • Teemo
    May be because I used a 64GB stick - "Windows 10 Disk Management tool only supports formatting a USB drive or hard drive which is smaller than 32GB to FAT32"
