Anyone know how this works. (Its only available with the electrically deployable tow bar). The manual is a little sketchy. How does it differentiate between weight in the boot and whats on the tow ball. All it says is its only available upto 60 mins after deployment. Doesn't say dont add any luggage etc. Just curious.
I had a quick play and it seems to electrically adjust the towbar (similar to deploying/stowing) to measure the weight, so nothing to do with what you put in the boot.
One would hope its designed well but there has been some alarmist posts on the forums. Excessive snaking and the like. My own experiences are that large vehicles overtaking me with the van on cause it to give a little wobble. The D4 was rock steady. However i did also change my caravan at more or less the same time as the car so unsure which one is causing it.
