    4 Zone A/C and the Auto buttons
    I normally keep the A/C at the same temperature in the car both front and back but turn down the rear temperature when the dog is on board.
    Following a query on the Phase 4 thread I am now puzzled regarding the function of the 2 Auto buttons on the dash.
    Can anyone explain how they work?
    No
  • Down & Dirty
    2018 HSE Now Gone
    I am now suffering from too many options fatigue!1 Rolling with laughter Embarassed
    As I have the 4 zone AC and was wondering as well what the difference would be between the 2 auto buttons on the front, I did check the imanual and... there is no difference at all, how stupid, why didn’t JLR didn’t give us the physical sync button as well? And as I was reading I did check the functions of the buttons of the second row as well and seems like I miss the physical sync button, whereas the manual states for my car I should have it... so I add the picture how it should be and question to other HSE lux owners with 4 climate zone, do you have the button on row 2 (number 7 on the picture)?
    With just the standard 2-zone aircon you do get a sync button Thumbs Up
  • Blackfly
    I don’t! Big Cry Two,auto buttons. I rarely use the back for passengers so I don’t mind that much
  • RotherhamPete
    If the driver or passenger manually change the airflow on their side, pressing the auto button on their side will return fan and airflow settings back to automatic control on their side only, leaving the other front seat occupant's fan or airflow setting unaffected.
    I have 4 zone air con and have three Auto buttons in the front and no Sync button in the rear.
    I have a sync button on the screen in the front though.
  • Blackfly
    Makes sense to me
    Interesting as I only have 2 upfront, now wonder whether I have the 4 zone or not.
    Russell, what other controls do you have? I have the ones in the second row, but are there others?
    @RotherhamPete: Just played a bit with the settings on the screen on indeed there is a difference between the 2 front auto buttons. If you change the direction of the airflow (let’s say towards feet for the driver and face for the passenger) and then press the auto button for the driver the passenger’s settings will remain on face, while the driver’s settings might change (and vica versa), but I don’t think you can actually change the fan speed separately for driver and passenger, only front and back fan speed is adjustable. Is this correct? And regarding the sync button mentioned in the iGUIDE for the second row, this is not a reality than, just some ‘error’ in the iguide or forgotten to be placed in the car...
    This is how mine looks like in the front, see picture. I do have the nanoe thing (number 4 on pic) as well, and just discovered in the iguide it should only work when airflow is to the face, not if the settings are on auto... nowhere else this was mentioned before buying this feature. Although when you manual select it, even when you are on the auto settings, it stays, but no idea if it actually works...
    Mine is the same, not sure about item 4, I would have to check.
  • Blackfly
    Now if only it could factor in outside humidity and produce a humide value as well as an outside temp
