  • kid
    2022 Discovery Si6 HSE Corris Grey
    Struggling to tow up hill
    HI all . Been towing TA caravan on the roads of spain for a week and from day one it has been struggling to tow up hill. Dropping down to 30mph at times up hill. I,am thinking fuel filter ? . cruise control O.K on the flat roads but on good on hills .Had tdv6 in D4 no problems. But this is a joke Big Cry .
    What engine and have you tried dropping it out of cruise control and see what iit does
  • Trevorb1
    The mono turbo TDV6 in D5 has the same quoted peak power and torque as the SDV6 in the D4 although the torque curve is not as flat as the twin turbo SDV6, I've not noted any deterioration in towing performance D4 to D5 although only towing 1500kg. Suggests there's something amiss if really struggling, possibly an air leak somewhere, if there is would expect a fault code or 2 to be logged.
    His profile says it is a TD6.
  • kid
    Yes its TD6 . If i had it in cruise control going up hill it well drop down to 30/40/ mph . When i come to a hill ,no c,c on its hard work foot full to the floor at times 3000 rpm max . Then very slowly it picks up by the time it gets to the top. Its had a service 2000 miles a go
    Mine tows a twin axle Swift and with ease up and down hills
    Went to France in August and some steep hills with no issues
  • kid
    Yes with ease on the flat . When i get back to Uk i will get the land rover dealer to look at it .Let you all know the outcome.
    Did you put the transmission in sports mode?
  • kid
    No never have when towing . It may well be a gearbox problem.
  • Qwertyd5x
    +1 for using sport mode when towing on hilly roads. The car has effortless power to tow up hills, but it struggles to respond to gentle pedal inputs.
  • MCD5 Downunder
    I recently bought a my18 TD6 and had similar issues and it ended up being a faulty intercooler water pump. Higher inlet temp restricted the boost to 15psi under load pulling my caravan.
  • TechnoTurkey
    My SD4 tows a decent sized caravan with no problems at all, I also agree that sport mode is good for the hills though!
